Airbag lampe lyser, + abs lyser og varsel lampe blinker
Thomas3B
Heisann! Airbag lampa mi lyser får opp denne feilmeldingen:
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58,75,76,77
Address 01: Engine Labels: Redir Fail!
Controller: 8D0 907 557 T
Component: 1.8L R4/5VT MOTR HS D06
Coding: 04001
Shop #: WSC 05319
VCID: 41F5C6075887
1 Fault Found:
00561 - Mixture Adaptation
14-00 - Adaptation Limit (Add) Exceeded
VCDS-Lite Version: Release 1.1
Tuesday, 05 February 2013, 17:01:42.
Control Module Part Number: 8L0 959 655 A
Component and/or Version: Airbag VW 3-S 0304
Software Coding: 00065
Work Shop Code: WSC 05311
VCID: 3C0BB7F33F65
5 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01222 - Shareware Version. To Decode all DTCs
36-10 - Please Register/Activate - Intermittent
01218 - Shareware Version. To Decode all DTCs
29-10 - Please Register/Activate - Intermittent
01219 - Rear Airbag Igniter; Driver Side (N201)
29-10 - Short to Ground - Intermittent
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
28-10 - Short to Plus - Intermittent
Abs lampa lyser og itillegg blinker varsel lampa, forsvinner tilfeldigvis av og til, men nå har den vært sånn en liten stund?
noen "kjente feil" ?
00561 - Mixture Adaptation: Adaptation Limit (Add) Exceeded
Possible Symptoms
Engine Jolting
Increased Fuel Consumption
Poor Idling/Jolting
Reduced Boost Pressure
Possible Causes
Mass Air Flow Sensor (G70) faulty
Fuel Pressure too Low
Leaks in Intake Air System and/or Exhaust System
Injector(s) faulty (i.e. coked)
Possible Solutions
Refuel Vehicle
Check Fuel System Pressure
Check Mass Air Flow Sensor (G70)
Check Intake Air System and Exhaust System for Leaks
Check Injection Quantity
Check Injector(s)
Når det gjelder airbag så har du jo to konkrete feil;
Du har ingen feilmelding på ABS, men det kan være feilkoden
trigges av ABS - lite trolig. Les av feilkoder etter du har kjørt, uten å stoppe motor først.
Administrator
Her er en jeg gjorde idag, siden forrige test har bilen vert på verksted og bytta regreim, osv..
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
test 2
VCDS-Lite Version: Release 1.2
Saturday, 20 April 2013, 19:10:17.
Address 01: Engine Labels: None
Coding: 04001
Shop #: WSC 05319
VCID: 41F5C6075891
2 Faults Found:
17967 - Throttle Body (J338): Fault in basic settings
P1559 - 35-10 - - - Intermittent
17967 - Throttle Body (J338): Fault in Basic Settings
P1559 - 35-10 - Please Register/Activate - Intermittent
Readiness: N/A
Address 08: Auto HVAC Labels: 1J1-907-044.LBL
Controller: 1J1 907 044
Component: CLIMATRONIC S 6.0
Coding: 02000
Shop #: WSC 05319
VCID: E4BBAF936743
2 Faults Found:
01206 - Signal for Duration of Ignition Off Time
01271 - Side Airbag Igniter; Front Driver SideTCs
airbag
Saturday, 20 April 2013, 19:42:20.
VCID: 3C0BB7F33F73
10 Faults Found:
01222 - 01222 - Crash Sensor Side Airbag; Passenger Side
01218 - Side Airbag Igniter; Front Passenger Side
01220 - Side Airbag Igniter; Rear Passenger Side
65535 - Internal Control Module Memory Error
01217 - Side Airbag Igniter; Driver Side (N199)
00588 - Airbag Igniter; Driver Side
00654 - Seat Belt Tensioner Igniter Driver Side
forresten noen plass jeg kan få full versjon, til OBD II som er kompatibel?
Her har det ballet på seg med feil, på airbag-deler er det ille, ellers må du bare grunninnstille gasspjeldet ditt.
VCDS som fungerer og du kan gjøre endringer med, kjøper du hos Ross-Tech. Din bil har ikke CAN-BUS, du klarer deg derfor med en noe billigere KII-USB Interface til $249. HEX-USB+CAN Interface som tar alt koster $100 mer.
Administrator
Hva med den ene ABS-feilen, er det en sensor som er gåen eller?
(01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent)
Noen ganger helt tilfeldig kicker ABS-en(bremsa) når jeg bremser og da skrur lyset seg av, helt tilfeldig igjen senere så piper det 3 ganger igjen, så er ABS lampa oppe og (!) blinker rødt.
må kanskje kjøpe ny Airbag-sentral? :)
Endret av Thomas3B
Når det gjelder 01203 - Electrical Connection between ABS and Instrument Cluster så står det No Signal - Intermittent. Dette betyr dårlig kontakt mellom ABS og instrumentpanel, da gjerne i en plugg.
01203 - Electrical Connection between ABS and Instrument Cluster: No Signal
Possible Symptoms
ABS Malfunctions
Possible Causes
Wiring between ABS and Instrument Cluster defective
ABS incorrectly coded
Instrument Cluster defective (rare)
Possible Solutions
Check Wiring between ABS and Instrument Cluster for Short to Plus
Check ABS Coding
Check Instrument Cluster
Administrator
Ok, bra. Jeg kjøpte akkurat en "ny" brukt en på ebay med nyere delenummer. Så det burde bli bra:)
Var det noe stress å skifte? Er det ikke bare 3 skruer som holder den på pumpa
Har faktisk ikke gjort no med denne enda, hvor mye kosta den delen på e-bay? :)
Men skal ikke være vansklig å bytte :)
Å skifte den elektriske delen på abs agregatet er fint på passat, du tar det fra innerskjermen, da slipper du og løsne abs agregatet og må lufte som et h... etterpå. Du løsner bare innerskjermen og spylevæsketanken så kommer du til på skruene
Fikk den for $100 inkl frakt:) så noen videoer på youtube, der det så ut som det var ganske rett fram å skifte den ja, så satser på det går i boks. Begynner å bli ganske lei den pipinga når feilmeldinga kommer
Okei, takk :)
fant en video her: VW B5: Passat ABS Module Removal for repair - YouTube
(ser ut som du har riktig opel, ifølge filmen :))
Edit:
Forresten Hallvard:
var det denne delen du kjøpte? : http://www.ebay.com/itm/AUDI-VW-PASSAT-A4-A6-S4-B5-Bosch5-3-Abs-Ecu-Module-Repair-Manual-From-UK-/271221072846?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f260923ce
eller denne?:
http://www.ebay.com/itm/Original-A4-B5-A6-C4-ABS-Steuergerat-Modul-Antiblockiersystem-ABS-4D0907379D-/170996264788?pt=DE_Autoteile&hash=item27d02bef54 (selve data brikka, vet at denne ikke passer)
Endret av Thomas3B
