Hjelp til å tyde feilkoder
Audi-s6
Jeg har fått noen feilkoder på bilen min nå. Vi trodde det var multifunksjonsbryteren som var ødelagt siden vi ikke fikk den i revers og nøytral. har byttet bryteren nå og får den fortsatt ikke i revers.. Tok ny feilkodesøk på den da kom dette opp. Noen som har peiling
VAG-COM Version: Release 409.1-US
Chassis Type: 4A - Audi 100/A6 C4
Scan: 01,02,03,08,15,17,25
Address 01: Engine
Controller: 4A0 907 557 B
Component: MOTOR D01PMC 1
Coding: 0261203645
Shop #: 1267358378
2 Faults Found:
00537 - Lambda (Oxygen Sensor) Regulation
08-10 - Control Limit Surpassed - Intermittent
00515 - Shareware Version. To Decode all DTCs
30-10 - Please Register/Activate - Intermittent
Readiness: N/A
Address 02: Auto Trans
Controller: 4A0 927 156 J
Component: AG4 GETRIEBE 018 D04
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
03-00 - No Signal
Address 03: ABS Brakes
Controller: 4D0 907 379 J
Component: ABS/EDS BOSCH 5 7592
Coding: 0265109024
Shop #: BB 37592
No fault code found.
00537 - Lambda (Oxygen Sensor) Regulation: Upper Limit
Possible Symptoms
Lambda Control inactive
Engine running rough
Possible Causes
Wiring and/or Connector(s) from/to Lambda Sensor(s) faulty
Lambda Control/Sensor(s) faulty
Injector(s) faulty/blocked
Fuel Pressure Regulator faulty
Fuel Pump faulty
Fuel Tank empty
Vacuum/air leaks
Possible Solutions
Check Lambda Control/Sensors
Check/Repair Wiring and/or Connector(s) from/to Lambda Sensor(s)
Check/Replace/Clean Injector(s)
Check/Replace Fuel Pressure Regulator
Check/Replace Fuel Pump
Check Fuel Level
Vacuum/smoke test hoses/valves and replace leaking ones
00537 - Lambda (Oxygen Sensor) Regulation: Lower Limit
Possible Symptoms
Possible Causes
Activated Charcoal Filter Solenoid Valve 1 (N80) leaking/sticking
Injector faulty (not closing completely)
Possible Solutions
Check/Replace Activated Charcoal Filter Solenoid Valve 1 (N80)
Check Fuel Pressure Regulator
00526 - Brake Light Switch (F): Circuit Malfunction
Possible Symptoms
MIL (Malfunction Indicator Light)
No Brake Lights
Possible Causes
Wiring and/or connections faulty between Brake Switch, Brake Lights and/or ABS Controle Module
Brake Light Switch (F) damaged
Brake Light faulty
Fuse(s) faulty
Possible Solutions
Check wiring and connections
Replace Brake Light Switch (F)
Check / Replace fuses(s)
Check / Replace Brake Lights
Check Brake Light Switch (F) in ABS Measuring Block
Special Notes
FAQ 2.7. Many Automatic Transmission Control Modules will show a DTC 00526 or 17087 that indicates a faulty brake light switch. This can be ignored and will not appear if you press the brakes once before checking for Fault Codes.
00526 - Brake Light Switch (F): Implausible Signal
Possible Causes
Wiring/Connectors from/to Brake Light Switch (F) faulty
Possible Solutions
Check/Repair Wiring/Connectors from/to Brake Light Switch (F)
Check/Replace Brake Light Switch (F)
Check Measuring Value Blocks (MVB)
Special Notes
Administrator
Dette kom også opp når vi kjørte vagcom
Control Module Part Number: 4A0 907 557 B
Component and/or Version: MOTOR D01PMC 1
Software Coding: 0261203645
Work Shop Code: 1267358378
1 Fault Found:
00515 - Camshaft Position (Hall) Sensor (G40)
30-00 - Open or Short to B+
Endret av Audi-s6
Teksten i feilkoden sier vel seg selv...
00515 - Camshaft Position (Hall) Sensor (G40): Open or Short to Plus
Possible Causes
Wiring to Camshaft Position (Hall) Sensor (G40) faulty
Camshaft Position (Hall) Sensor (G40) Installation faulty
Camshaft Timing Out of Specification
Possible Solutions
Check Wiring to Camshaft Position (Hall) Sensor (G40)
Check/Replace Camshaft Position (Hall) Sensor (G40)
Check Camshaft Timing
Check/Replace Engine Control Module
Administrator
