Hei.
Eg legger vegd et par linker til Megasquirt. :magic
http://msnordic.mine.nu/pages/msfaq/mtune.htm#mt
Må råde dere til å sjekke, og studere manual nøye, aller helst bør der være noen i nærheten som kan Megasquirt..
Eg vil og gi det rådet at dere kjøper ferdig kabelmatte med plugg !!
Og selvfølgelig et megasquirt som er ferdig med alle muligheter for å
Kjøre fordelerløs tenning og bredbandslambda ,
Husk og ta med bredbandslambda utstyret som står beskrevet.
http://www.diyautotune.com/
http://www.bgsoflex.com/megasquirt.html
Litt info..
24 MHz HCS12 processor,
Fuel control to 1 µsec (100 times more resolution than MegaSquirt-I),
Ignition control (full spark timing advance control, dwell control, etc) for one coil/distributor (7 pin HEI for example) and Ford's EDIS systems,
On-board stepper motor driver for IAC stepper control (this requires a few jumpers to be added on the MegaSquirt PCB to connect the socket jumpers to the DB37 connector),
Ford PWM idle valve support,
Built-in rev limiter, either 'fuel cut' or 'spark retard',
All tables are now 12×12 in size,
WBO2 AFR target table (in AFR units),
Independent dual-tables for VE and AFR target,
EGO feedback in wide-band mode is proportional to the difference between the measured AFR and the target AFR, the bigger the difference, the bigger the feedback step,
Spark advance table can have different rpm and kpa bins than VE and AFR tables,
115,200 baud serial interface with MegaTune2.25+,
CANbus networking *may* be added in next revision of hardware,
Barometric correction amount and direction configurable in software, and provisions for:
barometric correction based on initial MAP reading,
independent 2nd barometric MAP sensor for continuous real-time baro correction, or
no baro correction.
TPS values for open loop and flood clear mode are user configurable,
MAP based open loop can be set as well as TPS,
Both TPS and MAP based accel enrichment is built into the code, you can configure the ratio of each,
Blended Alpha-N and speed density is an option,
2 spare I/O lines for custom controls. (This is in addition to 4 lines for Idle stepper control if you don't need this, or the Fast idle solenoid then becomes a spare if you do use a stepper motor.)
