kicker forsterker mono vs 2kanals til subb
maxhp
Jeg lurer på hvilken forsterker som ville vært best til å bruke på en
Kicker L7 750WRMS duel 4Ohm såm kan parallell kobles i 2Ohm eller 8Ohm.
jeg lurer på hivlek forsterker som ville vært best til å bruke på subben:
Kicker forhandler
2006 Kicker ZX850.2
2-Channel Amp Specifications
Amplifier Type: 2-channel
RMS Power @ 4 Ohms: 295W x 2 @ 14.4V
THD at 4-Ohm RMS Power: <1 %
Bridged RMS Power @ 4 Ohms: 850W x 1 @ 14.4V
Speaker Level Inputs: yes
Preamp Outputs: yes
Built-In Crossovers: HP/LP
Bass Boost: 0-18 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: 93 dB
Features:
Advanced chassis with extruded aluminum heatsink
MOSFET class A/B power supply
Top-mounted controls
KickBass 0-18 dB variable bass boost at 40 Hz
Variable 50-200 Hz high- or low-pass crossover with 12 dB/octave slope
High level or low level inputs (125mV-10V)
PreAmp Signal Transfer (PAST) RCA outputs
Delayed turn-off logic circuit
Soft start turn-on circuit for reduced startup load
Short circuit, Over-voltage, Reverse polarity, Thermal overload (SORT) protection
Included remote KickBass control
Fully CEA-2006 compliant specifications for real-world power
ELLER:
Kicker forhandler
2006 Kicker ZX1000.1
Subwoofer Mono Amp Specifications
Amplifier Type: Mono
RMS Power @ 4 Ohms: 500W x 1 @ 4 ohms
Bridged RMS Power @ 4 Ohms: 1,000W x 1 @ 2 ohms
Preamp Outputs : yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 25-200Hz
Signal to Noise Ratio: 60 dB
Model ZX1000.1 Fuse 100A PowerGroundWire 1/0GA
Features:
Efficient class D circuitry
Variable 50-200 Hz low-pass crossover with 24 dB/octave slope
Defeatable 25 Hz subsonic filter
hvilken ville vært best??
all hjelp takkes for
KJør klasse kjør stil, kjør japsebil
gå for monoblokka å du blir garantert fornøyd. jeg kobla igår en dynabel bf4501 på en s12L7d2, dvc 2ohm. blir sagt dynabel`en skal gi ca 1200w i 1ohm, og kickeren slukte hver watt i en lukket kasse på ca 50L ;)
L7`en er ikke så altfor lettdreven og den 2kanaleren vil ikke tåle 2ohm mono, vil berre få plager med at protection slår inn og kobler ut alt, i tillegg til at det normalt ikke gis garanti på forsterkere som blir brukt til noe de ikke er laget for. og i 8ohm mono vil 2kanaleren gi ca.400w, noe som vil bli oki, men L7`våkner til live når den får 700w++.
og du vil sikkert ikke legge merke til så mye forskjell på "kontrollen og lydkvalitet" om du har L7`n på en 2kanaler brokoblet i 8ohm eller på en monoblokk i 2ohm.. vil nok tørre å si at en zx1000.1 har nok kontroll og krefter til å holde en L7 i sving på en skikkelig måte.
når det gjelder brokobling og slikt så er en 4ohm stabil 2kanaler beregnet for en 4ohms last målt på terminalene..
ikke bry deg om hva den vil "se" innvendi.. gå ut ifra hva produsenten sier om hvilke watt den leverer i hvilke ohm.. og det er ohm som er målt på terminalene.
sier de 4ohm stable mono/bridged, ja så er det totalt oki med en 4ohms subb... ved 4ohm brokoblet vil hver av kanalene se det som 2ohm..men det er fortsatt 4ohm mono..og det er derfor effekten blir doble utifra 2x 4ohm stereo, og totalen av 2x 2ohm stereo.
slik utregning av watt er vel teoretisk..men en god forsterker med god strømforsyning burde kunne forsvare slike tall.
1986 bmw 318i
1987 Ford Escort xr3i
