        SR20De
                Innholdsteller276
Alt skrevet av SR20De
	Takker for alle svarene. Dette vil altså ikke koste så mye å fikse?
	Hørtes ut som om det kom fra venstre-bak.
	Prøvekjørte en Primera SRi her om dagen (P10). Merket det var litt piping når jeg kjørte i dumper. Eieren påsto det kom fra bremsekalippern, men jeg vet ikke helt. Hva kan være feil?
	Nye bremseslanger til Manta B foran selges. Tror de kanskje passer til Ascona B også, men det skal jeg ikke si helt sikkert. Nypris: 493,- Selges kr 250,- Har kvitteringen.
	En på forumet på http://www.g20.net skrev dette: Okay... here's a little list of tire sizes & required offsets for the P11 & P10. This list has been compiled based on knowledge I have gained from buying, selling, testing, & just talking about wheels on the G20. If I have not tested it myself, then I have talked to someone who has...otherwise, the parameters are based on calculations derived from tested & known fitments. Please review & let me know if there are any other known combos that I may have missed. P11 tire fitments: *195/60/15 - 24.2" diameter (35-45mm offset required)*(99-01 Touring) *195/65/15 - 25" diameter(35-45mm offset required)*(99-02 Standard) 205/50/15 - 23.1" diameter (35-45mm offset required) 205/55/15 - 23.9" diameter (38-45mm offset required) 195/50/16 - 23.7" diameter (35-45mm offset required) 205/45/16 - 23.3" diameter (35-45mm offset required) *205/50/16 - 24.1" diameter (35-45mm offset required)*('02 Sport) 215/45/16 - 23.6" diameter (38-45mm offset required) 225/40/16 - 23.1" diameter (42-45mm offset required) 225/45/16 - 24" diameter (42-45mm offset required) 205/40/17 - 23.5" diameter (35-45mm offset required) 205/45/17 - 24.3" diameter (38-45mm offset required) 205/50/17 - 25.1" diameter (38-45mm offset required) 215/40/17 - 23.8" diameter (38-45mm offset required) 215/45/17 - 24.6" diameter (40-45mm offset required) 225/40/17 - 24.1" diameter (42-45mm offset required) 225/45/17 - 25" diameter (42-45mm offset required) 215/35/18 - 23.9" diameter (38-45mm offset required) 215/40/18 - 24.8" diameter (40-45mm offset required) 225/35/18 - 24.2" diameter (42-45mm offset required) 225/40/18 - 25.1" diameter (42-45mm offset required) 215/35/19 - 24.9" diameter (42-45mm offset required) 225/35/19 - 25.2" diameter (42-45mm offset required) *stock setup Note on P11 offsets- All offsets listed assuming the car is not lowered more than 3"... otherwise, fender lip trimming may be required... also, in most cases, a 2-6mm spacer may be used on the rear just for the purpose of making the width of the rear track visually match that of the front(not neccesarily a performance gain). P10 tire fitments: 185/60/14 - 22.7" diameter (35-45mm offset required) 185/65/14 - 23.5" diameter (35-45mm offset required) 195/55/14 - 22.4" diameter (38-45mm offset required) *195/60/14 - 23.2" diameter (35-45mm offset required)*(91-93 P10) *195/65/14 - 24" diameter (35-45mm offset required)*(93.5-96 P10) 205/60/14 - 23.7" diameter (38-42mm offset required) 195/50/15 - 22.7" diameter (35-45mm offset required) 195/55/15 - 23.4" diameter (35-42mm offset required) 195/60/15 - 24.2" diameter (35-38mm offset required) 205/50/15 - 23.1" diameter (38-42mm offset required) 205/55/15 - 23.9" diameter (38mm offset required) 195/50/16 - 23.7" diameter (35-42mm offset required) 205/40/16 - 22.5" diameter (38-45mm offset required) 205/45/16 - 23.3" diameter (38-42mm offset required) 205/50/16 - 24.1" diameter (38-40mm offset required) 215/40/16 - 22.8" diameter (40-42mm offset required) 215/45/16 - 23.6" diameter (40mm offset required w/ 7.5" rims...40-42mm w/ 7" rims) correction 205/40/17 - 23.5" diameter (38-40mm offset required) 205/45/17 - 24.3" diameter (38mm offset required) 215/40/17 - 23.8" diameter (40mm offset required w/ 7.5" rims...40-42mm w/ 7" rims) 215/35/18 - 23.9" diameter (40mm offset required w/ 7.5" rims...40-42mm w/ 7" rims) *stock setup Note on P10 offsets & sizes available- All offsets listed assuming the car is not lowered more than 3"... otherwise, fender lip trimming may be required... some other sizes & alternate offsets are known to fit a P10 with the use of spacers, and/or trimming the fender lips. Example of sizes known to fit P10 w/ clearance modifications: 225/40/16(40mm offset) 215/35/19(40mm offset) Wheel width ranges that will work with all tires listed above: 14x6-14x7 15x6-15x7 16x6.5-16x7.5 17x7-17x8 18x7-18x8 19x7-19x8
	Du har metallic-lakk du? Må da ha klarlakk da... Hvor kjøpte du lakkboksene da?
	KH3 er tettfarge, trenger ikke klarlakk da. ;) På metallic må man ha klarlakk.
	Lakk til motorrommet er ofte tilsatt matteringsmiddel, slik at den blir matt. Er ikke så mange biler som har det blankt i motorrommet. Ofte har de en annen farge også i forhold til den utvendige lakken. KH3 er vel ei farge som det bare brukes ren svart i, så jeg tviler på at det er så mange nyanser av denne fargen. Bare si fargekoden så får du vel riktig lakk, med mindre du ber om lakk som skal brukes innvendig.
	På min (1.8 GL) som er fra 1986 så må jeg fylle 98 super.
	Noen som har noen filmer av Primera, eller vet om noen linker? Tenkte på P10. NissanPrimera har jo lagt ut 3 filmer, men er det noen som vet om flere?
	Er nok riktig det Loppa sier. Men, det skader jo ikke å klage heller. Dette burde oppretterne fixe for deg!
	Ja... Er alle SRi`er (P10) like? Eller er det gjort noen endringer på noen årsmodellene? Noen som vet om noen tester av denne bilen?
	Noen som vet om noen linker med ganske mye informasjon om SRi`n (P10)?
	Noen som vet 0-100 tider på SRi og GT? Tenkte på P10 og P11. Er GT verdt de ekstra kronene?
	http://www.billakk.no Gå så på verktøy. Ikke regn med at disse sprøytene er billige, skikkelige sprøyter koster $$$$
	Har handlet to ganger hos Autospar, har fått varene innen 4-5 dager hver gang. Syns ikke det er så ille!
	Sikker på at det ikke ble satt inn sterkere pære enn 55w? Hvis det ikke går ann å bruke vanlige 55w som vi har i Norge så er vel ikke lyktene så brukbare?
	Ok, takker for svar. Men, hva er finest? Med eller uten hull? :rolleyes:
	Lurte på om det egentlig skal være hull tvers igjennom på GTI-leppa som sitter på 90-fanger? Har ei ny leppe liggende og den er det ikke hull i.
