  1. I dag
  2. ACSM Certified Clinical Exercise Physiologist CEP Exam Questions help clinicians build practical skills that improve patient recovery. As an ACSM CEP, you learn evidence-based protocols for cardiac, pulmonary, and musculoskeletal rehab. This knowledge speeds recovery, reduces complications, and boosts patient confidence. Clinicians use exercise testing, tailored programs, and progress tracking. These tools improve mobility, reduce pain, and restore function. Moreover, ACSM Certified Clinical Exercise Physiologist CEP Exam Questions prepare professionals for real-world cases. As a result, rehab teams work better together. Consequently, patients move home sooner and need fewer readmissions. For career growth, certification opens doors. Employers prefer ACSM CEPs for specialized rehab roles, leadership posts, and research work. Also, certified clinicians earn higher pay and gain trust from patients and peers. Therefore, investing in exam prep pays off fast. Why I select Certboosters: they offer focused practice tests, clear explanations, and realistic exam simulations. Their materials match the exam blueprint and save study time. In short, it helps candidates pass confidently and start stronger careers in patient recovery and rehabilitation. Start now with targeted practice, track your progress, and apply what you learn in clinics to help patients recover faster. Join focused study today and accelerate your career growth.
  3. Siste uke
  4. Det virker som det er helt sykt mye "vandring" på det hjulet, så det hjulet som styrer selve flappen hopper ut og lager en kneppelyd. Når jeg skrur gradene ned igjen så hopper den inn i sporet til slutt. Eneste forskjellen jeg kan se på andre videoer på youtube er det plasthjulet som sitter i motoren har ikke Dette er motor nr 2 jeg tester, samme skjeddde på forrige. Grunnen til at den ble byttet i første omgang var fordi det blåste varmt på en siden og kaldt på andre siden, men har planer om å bytte matrix heater i løpet av nærmeste ukene som forhåpentligvis fikser dette. Filmet og la ut en liten video av det her.
  5. Jeg legger det inn for ettertiden: https://bilhobbyverksted.no/
  6. Hva er mest sannsynlige feilkilden når cruicecontrol fungerer i blant, kabel, bryter eller andre ting? Noen ganger så slår den på med en gang jeg trykker på Cruicekontroll knappen og andre ganger så vil den ikke på. Funksjonen LImit fungerer stort sett hele tiden uten problemer. Har nullstilt ratt sensoren med å vri rattet, men fungerer fortsatt dårlig.
  7. Hei, har en Peugeot Expert dieselbil som ble fylt bensin på for en litt stund siden. Bilen ble startet og kjørt til den begynte å hoste. etter det har tanken blitt tømt og renset, samt slanger og dieselfilteret. så har bilen godt 5-600km med diesel i systemet og starter og går fint. helt til igår da den plutselig ikke ville mer. Motoren går fremdeles og i fri virker den fint, får opp turtall og ting virker greit. Men når man løser ut clutchen og det blir motstand på motoren så detter turtallet og motoren dør dersom man ikke trykker inn clutchen igjen.. Noen som har noe gode råd til hva som skjer? Er det dysene som er gåen? Eller er hele motoren ferdig?
  8. Da svarer jeg meg selv . Tok ut sikringen for starter og satte på direktestrøm til starter og den starter feil melding borte. Er det noen her som har måttet bytte tenningslås ? problemer med at starter ikke slår inn. Peugeot svarer at det ikke er noe problem på disse bilene
  9. Denne har feilmelding Economy mode active. Hvordan få bort feimelding slik at motoren starter ?
  10. Har en minusstyrt Subaru Justy 2010. Får ikke ledbar til å fungere. Etter tips har jeg koblet slik via rele. Men neida. Noen tips?
  11. Tidligere
  12. Noen vet hvordan man bytter spylemotor på touran.må inneskjermen av?
  13. Med strøm av tid С течением времени Im Lauf der Zeit
  14. Har en Mercedes Benz E 220 CDI 2002 mod. Her har Reimhjul på veivakslingen gått i stykker, OEM A6110301303. Dette er ikke å skaffe noen plass, Finnes det noe erstatning som kan brukes ? Regner med at det er andre som har hatt samme problem.
  15. Har en Vito fra 2021 (W447?) der jeg ønsker å endre fra 3-seter til 2-seter. Jeg har fått tak i brukte seter fra en W447 (ifølge selger) men ser at kontaktene under setet er forskjellig fra det som er på bilen. Til passasjersetet er det en større gul felles kontakt med ledninger til alle fire plugger og en mindre hvit kontakt på bilen. Men på setet jeg har fått tak i er det bare en gul kontakt med ledninger kun til høyre og venstre plugg. Jeg går utifra at det ikke er varme i setet jeg har kjøpt, men det er det i originalsetene. Det som blir venstre side av pluggene på bildet ser ut til å være setebeltevarsling, men hva er den andre pluggen? Når jeg plugger dette sammen, så får jeg feilmelding og airbag-lys for passasjersetet. Er det noen som har endret fra 3 til 2 seter på Vito før, som vet hva de forskjellige pluggene er til og hvordan dette kan kobles? Første bilde viser kontaktene som er på bilen, bilde nr2 viser kontakten på passasjersetet.
  16. har en Mercedes c220, 2003model. har problem med henger kontakten (13pin) har vert folk å koblet på dette en gang før, å nå er noen ledninger kappet og div. men når jeg tester kontakten så får jeg konstant strøm på pin 1 og 5 (når bilen er av) men får ikke noe signal på resten av pinsa uansett om bilen sviver eller ikke å uansett hvilke lys jeg setter på. så lurer på om noen med sikkerhet kan si hvilke farger som skal i hvilke pin? å om eventuelt kontrollboksen kan være deffekt? delenr(031 545 72 32 (02) ) ledningene som går fra boksen å til kontakten har fargene: (tykk brun, tynn brun, tykk rød og gul, hvit og sort, sort og grønn, grønn og hvit, rød og grå, gul og grå, rød og sort, og siste sort og grå.)
  17. Har forsøkt å sjekke bl.a. med ChatGPT for å få forslag til alternativer for å fjerne/stoppe rust på karroseri/understell på en Merc ML fra 2009. Tenkte først å bruke lanolin for å binde rusten, men fikk også forslag om å benytte stoffer basert på fosfor- eller tanninsyre først for å fjerne og binde rust. Product Key Ingredients Why It’s Good Notes Corroseal Tannic acid + Latex primer Converts rust + primes in one step Easy to apply with a brush Fertan Tannic acid Penetrates deeper rust layers Needs rinsing after 24 hours Eastwood Rust Converter Phosphoric acid base Fast-reacting, good for spot rust Needs top coat afterward POR-15 Metal Prep + POR-15 Paint Phosphoric prep + Moisture-cured topcoat Extremely durable A bit more work, but long-lasting Har sjekket litt på POR-15 som ser veldig lovende ut, og som forhandles i Norge av gasolin.no. Skulle gjerne hatt kommentarer fra noen som har erfaring fra bruken og evt som bruker det profesjonelt. De som vil ha en link til ChatGPT infoen kan finne det her : https://chatgpt.com/share/e/687a6627-2820-8002-ac69-66ab6b9b4d78 Per W.
  18. Hei Den leppa nederst på støtdemperen som skal inn i sprekken på hubben ramlet av, gjørt det noe?
  19. Hei igjen. Begynner å bli litt gammel denne forespørselen, men jeg prøver likevel 🤞 Lyden har for så vidt forsvunnet, men varmeapparatet blåser varmt kun på førerside. På passasjersiden kommer det bare kald luft, spesielt på beina. Godt mulig aktuatormotorer som du sier da!? Sliter litt med å finne det. Heter det aktuatormotor, eller kalles det noe annet også? Og det er flere også?
  20. Ingen som har hatt liknandes problemer ?
  21. Noen som kan låne eller vet hvor man kan kjøpe en indikator klokke for å sett en camshaft f.eks? Trenger en i US imperial og med avstand 25mm/1 tomme. på forhånd takk
  22. Q7-en min (plug-in hybrid) har gått 210 tusen km og er en super bil. Den har nå fått en lyd ved ca 1200 omdreininger/min. Hva kan det være? Ingen lyd ved el-kjøring. Ingen lyd ved clutch-ing når dieselmotoren kobles inn/ut. Ingen lyd ved turtall over ca 1200 omer. Full fres som vanlig ved «aktiv kjøring». Lyden er omtrent som dieselmotorlyden i Passat 2007-modell.
  23. Kjøpt meg en 1991 G30 og lurer på om hva som må til for å montere facelift front fra 1993- på min? Er bilene identiske eller hva skiller før og etter facelift?
  24. Hei. Dette gjelder en Fiat Scudo Dangel 2013 modell. Jeg har demontert drivakselen på høyre side altså passasjer siden. Slik jeg forstår det er det en kort driv aksel på fører siden, og altså en lang på passasjer siden (to deler, sammensatt til 1 del/drivaksel). 1_Jeg har nå fått av driv knuten som hører til hjul siden, men jeg klarer ikke få tripod siden (den siden som peker innover mot girkassen) ut av "huset" sitt. Når jeg har funnet videoer av folk som demonterer lang driv aksel, så popper tripod lett som en plett ut, etter at de har fjernet klemme & støv mansjett. Slik er det ikke på min driv aksel, tripod er på en måte festet med noe, slik at den er fastmontert inne i "koppen". Er det noen som vet om visse drivaksler som er type lang, rett og slett ikke kan demonteres helt ifra hverandre ? Jeg synes det er litt merkelig, for jeg har funnet reserve del/driv aksel, som skal da kunne monteres inn i denne "koppen" på drivaksel (tror i hvert fall at jeg har funnet det, men jeg kan jo ta feil). Jeg skulle gjerne fått demontert alt, slik at jeg kan rengjøre og få inni nytt fett, osv. 2_ Når jeg dro drivakselen ut av girkassen, kom det ingen gir olje ut. Tyder dette på for lite gir olje, eller er det kun sjåfør siden det kommer ut gir olje når man demonterer en driv aksel? (Jeg har ikke demontert den siden, men vet forrige eier gjorde det) 3_Hvis du ser på et av de bilder som er tatt mens driv aksel fortsatt står i girkassen, så ser du kanskje den svarte stangen/staget som er foran tripoden. Finnes det en hack for å gjøre det lettere å få drivakselen på plass igjen, forbi dette staget/avstiveren (forsøkte demontere, men det gikk dårlig) Tripoden har litt vanskeligheter for å passere det punktet. Og det var ikke lett få den ut, så er litt bekymret mtp montering.
  25. Det er alt for kraftige riper til at det finnes en enkel løsning. Skadene kan kanskje begrenses noe ved at du bruker en claybar og får det polert opp igjen med maskin. "Billigste" løsningen vil nok være å bruke forsikringen om du har full dekning. Blir veldig synlig på svart bil om du prøver å bøte på det med sprayboks. Blir en vurderingssak i forhold til verdien på bilen.
  26. Hei. Noen som har noe tips? Klimaanlegget driver å tuller. Slår på tenningen og viften starter med lite styrke. Prøver og justere styrken, skjer ingenting. Og plutselig noen ganger så går alt på full styrke, og klarer ikke å stoppe det selv ved tenningen av. Så må fysisk skru av ene kabelen på batteriet eller ta ut kontakta på motstanden som vist på bildet. Hvordan vet jeg om motstanden til kupevifta er gåen? Takk for tips! link til video og bilde: https://www.transfernow.net/dl/2025082975tgelAq
