koder feil
Eirik Skoglund
P1563 info under:
17971/P1563/005475 - Quantity Adjuster (N146): Lower Limit Reached [h=4]Possible Symptoms[/h]
  • Malfunction Indicator Light (MIL) ON
  • Reduced Power
  • Engine jerking
[h=4]Possible Causes[/h]
  • Fuse(s) faulty
  • Wiring and/or Connector(s) from/to Quantity Adjuster (N146) faulty
  • Quantity Adjuster (N146) not adjusted
  • Quantity Adjuster (N146) blocked/faulty
[h=4]Possible Solutions[/h]
  • Check Fuse(s)
  • Check Wiring and/or Connector(s) from/to Quantity Adjuster (N146)
  • Check/Adjust Quantity Adjuster (N146)
  • Check/Replace Injection Pump
P1163 info:
17571/P1163/004451 - Fuel Temp Sensor (G81): Open or Short to Plus [h=4]Possible Symptoms[/h]
  • Fuel consumption higher then normal
  • Starting the engine is not as easy as normal
  • Emission Levels not met
  • Wiring/Connectors from/to Fuel Temp Sensor (G81) faulty
  • Fuel Temp Sensor (G81) faulty
  • Check/Repair Wiring/Connectors from/to Fuel Temp Sensor (G81)
  • Check/Repair Fuel Temp Sensor (G81)
P1550 Info:
17958/P1550/005456 - Boost Pressure Control Valve (N75): Control Deviation [h=4]Possible Symptoms[/h]
  • Engine misfiring/juddering/running rough
  • Power Loss / Limp Mode
  • Hoses/Pipes incorrectly connected, disconnected, blocked or leaking
  • Charger Pressure Control faulty
    • Solenoid Valve for Boost Pressure Control (N75) faulty
    • Turbocharger faulty
    • Vacuum Unit for Turbocharger faulty
  • Check Hoses/Pipes to/between Components
  • Check Charge Pressure Control
    • Check Solenoid Valve for Boost Pressure Control (N75)
    • Check Turbocharger
    • Check Vacuum Unit for Turbocharger
Info om feilkoder finner du her,bare og søke på feilkoden oppe i høyre hjørne på siden.
Link til Ross tech:Category:Fault Codes - Ross-Tech Wiki
Peugot 407SW
Alfa Romeo 156 Selespeed(Til salg)
VW Golf IV(solgt)
