Hifonics 12" og Momo polk 6,5" selges!
Terjeo
Selger 2 stk hifonics olympus olm 2412 subber, og et Momo polk 6,5 frontsett.
Subbene er strøkne, frontsettet er nesten ikke brukt men har stått montert i bil. Det er noe sika rester på delefiltrene da de var limt inne i dørpanelet.
Spiller meget pent!
Jeg kan frakte fra på strekningen Kragerø - Lørenskog
Befinner meg i horten for øyeblikket.
5000,- for subbene
1500,- for frontsettet
6000 for alt!
PM eller 95009504!
Info om subber:
The Hifonics Olympus OLM2412 is a dual ohm 12” subwoofer built from a fiber-glass infused FEA structured cone. The third subwoofer in the Olympus series, the OLM2412 is a large upgrade from the OLM1612 and a humongous upgrade from the weak powered HiFi, Titan, and Brutus series subwoofers.
The OLM2412 offers a massive 4800w of peak power handling (versus 3200w from the OLM2412) and 2400w of nominal power handling (versus 2400w). In addition, the OLM2412 features the OLM1612’s 1” hi-excursion surround, double-laminated integrated spider tinsel-lead design, and push & insert wire terminals.
Nypris ca 10 000/stk
Info om frontsett:
Driver Complement
Mid/Woofer 1 - 6-1/2" Diameter (16.51cm)
Woven Carbon Fiber
Tweeter 1 - 1" Diameter (2.54cm)
Silk/Polymer composite dome
Electrical
Overall Frequency Response 43Hz - 25kHz
Nominal Impedance 4 ohms
Power Handling (continuous) 125 w
Power Handling (peak) 250 w
Efficiency 90 dB
Crossover 2.6kHz 2nd order High & Low Pass
Crossover Dimensions 6" x 3-5/8" x 1-1/2"
(15.24cm x 9.21cm x 3.81cm)
Voice Coil Diameter: Driver 1" (2.54cm)
Voice Coil Diameter: Tweeter 1" (2.54cm)
Driver Mounting Depth
Top Mount 2-11/16" (6.83cm)
Bottom Mount 2-13/16" (7.14cm)
Grille
Height 9/16" (1.43cm)
Diameter 6-5/8" (16.83cm)
Cut-out
Driver Cut-out Diameter 5-1/16" (12.86cm)
Thiele/Small Parameters
Resonant Frequency 86 Hz
Qms 10.95
Qes .98
Qts .9
Vas 5.52 L
Cms 288 Micro Meters
Bl 4.6 Tesla Meters
Sd 116.9 sq. cm
Mms 11.72 g
1996 Omega B 3,2 Prosjekt
