tyrkia007 Skrevet November 15, 2010 Rapporter Share Skrevet November 15, 2010 Hei jeg har funnet følgende feil med vag commen. hjelppp!! VAG-COM Version: Release 311.2-N Chassis Type: 9N1 - VW Polo Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69 Address 01 ------------------------------------------------------- Controller: Note: Can't Synch Baud Rate Address 03 ------------------------------------------------------- Controller: Address 08 ------------------------------------------------------- Controller: 6Q0 907 044 A Component: CLIMAtronic PQ24 0201 Coding: 0000000 Shop #: WSC 00000 5 Faults Found: 00818 - Sensor for Evaporator Outlet Temperature (G263) 010 - Open or Short to Plus 00710 - Defroster Flap Positioning Motor (V107) 000 - - 01271 - Positioning Motor for Temperature Flap (V68) 000 - - - Intermittent 01272 - Positioning Motor for Central Flap (V70) 000 - - - Intermittent 01274 - Air Flow Flap Positioning Motor (V71) 000 - - - Intermittent Address 09 ------------------------------------------------------- Controller: 6Q1 937 049 C Component: 00 BN-SG. 1S32 Coding: 26046 Shop #: WSC 00788 1 Fault Found: 01598 - Drive Battery Voltage 07-10 - Signal to Low - Intermittent Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 6Q0 920 801 Component: KOMBI+WEGFAHRSP VDO V12 Coding: 01141 Shop #: WSC 00000 WVWZZZ9NZ3Y013659 VWZ7Z0B5092791 No fault code found. Address 19 ------------------------------------------------------- Controller: 6N0 909 901 Component: 00 GATEWAY CAN 1S32 Coding: 00014 Shop #: WSC 00788 No fault code found. Address 44 ------------------------------------------------------- Controller: 6Q0 423 156 M Component: LenkhilfeTRW V210 Coding: 00140 Shop #: WSC 00788 No fault code found. Address 46 ------------------------------------------------------- Controller: 6Q0 959 433 E Component: 3M Komfortgerát 0001 Coding: 00066 Shop #: WSC 00788 No fault code found. End ------------------------------------------------------- Siter 9x golf 3 1.8 gt/tdk 1x celica 98 mod 1.8 15 x corolla e9 1.3/1.6 xli 1x vw polo 2002 1.4 Lenke til kommentar Del på andre sider More sharing options...
Bwana Skrevet November 15, 2010 Rapporter Share Skrevet November 15, 2010 Er noe herk med slike automatiske klimaanlegg :( Risikerer jo å fryse i hjel når noe av automatikken feiler. Bør vel starte med å gå over alle kontakter for å se om noe kan være falsk alarm. Så var det denne 09-CentralElectronics også som klager over low battery voltage. Kan muligens også tyde på noe kontakt/ledningsproblem. For du har vel nok spenning fra batteriet? Kan finne litt mere tips om feilkodene her: http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes .... men hva er det som egentlig er problemet med bilen ? Siter Lenke til kommentar Del på andre sider More sharing options...
tyrkia007 Skrevet November 15, 2010 Forfatter Rapporter Share Skrevet November 15, 2010 problemet med bilen er at baklysene funker ikke når jeg bremser?! epc lampa lyser og abs/indikasjon (trekant ) lyser ! Siter 9x golf 3 1.8 gt/tdk 1x celica 98 mod 1.8 15 x corolla e9 1.3/1.6 xli 1x vw polo 2002 1.4 Lenke til kommentar Del på andre sider More sharing options...
Grev1 Skrevet November 16, 2010 Rapporter Share Skrevet November 16, 2010 Har du sjekka bremselyskontakta og pærene? Siter Octavia MK2 Golf MK4 RX7 FC Lenke til kommentar Del på andre sider More sharing options...
tyrkia007 Skrevet November 16, 2010 Forfatter Rapporter Share Skrevet November 16, 2010 pærene er hele har til og med byttet de. bremselyskontakt? bryter elr? elr bare kontakta? Siter 9x golf 3 1.8 gt/tdk 1x celica 98 mod 1.8 15 x corolla e9 1.3/1.6 xli 1x vw polo 2002 1.4 Lenke til kommentar Del på andre sider More sharing options...
Grev1 Skrevet November 16, 2010 Rapporter Share Skrevet November 16, 2010 Tenkte på brytern ja. Siter Octavia MK2 Golf MK4 RX7 FC Lenke til kommentar Del på andre sider More sharing options...
tyrkia007 Skrevet November 16, 2010 Forfatter Rapporter Share Skrevet November 16, 2010 jeg har byttet bryteren men ingen reaksjon!!! Siter 9x golf 3 1.8 gt/tdk 1x celica 98 mod 1.8 15 x corolla e9 1.3/1.6 xli 1x vw polo 2002 1.4 Lenke til kommentar Del på andre sider More sharing options...
tyrkia007 Skrevet November 17, 2010 Forfatter Rapporter Share Skrevet November 17, 2010 ingen som kan hjelpe meg elr? Siter 9x golf 3 1.8 gt/tdk 1x celica 98 mod 1.8 15 x corolla e9 1.3/1.6 xli 1x vw polo 2002 1.4 Lenke til kommentar Del på andre sider More sharing options...
Bwana Skrevet November 17, 2010 Rapporter Share Skrevet November 17, 2010 Siden du har så mange feilmeldinger, også på ting som du ikke sier å ha problemer med, tyder det på mulig dårlig spenning eller kontakt til noen kontrollenheter. Legg merke til at du ikke har fått noe reaksjon i det hele tatt på adresse 03 som burde være ABS. Burde prøve å sjekke spenninger etter tenningslås, og kjøre VAG-COM igjen, spesielt på 03:ABS. -- Siter Lenke til kommentar Del på andre sider More sharing options...
