D-1 Skrevet November 9, 2004 Rapporter Share Skrevet November 9, 2004 hva må til for å montere en g-lader (G60) på en GTi 16v motor?? (Utenom G-laderen) Siter itj sant Skrapbil med mange farger snart renovert til vidunder bil med samme farge! he he....... Lenke til kommentar Del på andre sider More sharing options...
Polo Classic Skrevet November 9, 2004 Rapporter Share Skrevet November 9, 2004 Fra ORZ-Motorsport: G-Lader mounting brackets and belt tighter G-Lader exhaust (silencer box) Serpentine pulleys for Water pump and Alternator Throttle Body, complete Fuel Injectors and Pressure Regulator Idler Valve Digifant1 ECU Engine Wire Harness Oxygen Sensor Water Temperature Sensor (blue) CO% Potentiometer Relays, Fuel Pump Pressure Hoses to and from the G-Lader Lower Water Pump Pipe Radiator Catalytic Converter (if needed) Special cylinder head gasket, metal Engine/crank breather system By-pass pipes and hoses Special Rod Bearings Water distributor for Water temperature Sensors Stainless Steel Fuel Rail Crank Shaft Pulley Bracket for Pulley and Serpentine Belt guiding Roller Alternator mounting brackets Serpentine Belt (to use with 70mm G-Lader pulley) 70mm G-Lader Pulley Hydraulic/Spring Loaded tensioner ,Cylinder Head Bracket for the Hydraulic/Spring Loaded Tensioner Hoses for Intake Manifold and Throttle Body connections Stainless Steel By-Pass lines Special Spark Plugs Siter No SPEAKERS NO BODYKITS NO BULLSHIT M3-speil, like moderne som bakrutesjalusi M3-speil, M3-sideskjørt og RS-fangere, også kalt nybegynnerfeil Lenke til kommentar Del på andre sider More sharing options...
