aleks85 Skrevet November 16, 2013 Rapporter Share Skrevet November 16, 2013 har en del feil meldinger på girkassa, noen som vet hva 18179 er? har søk på ross tech sine sider men finner ikke noe Er en audi a4 1.8t automat 96modell Her er alle feilmeldinger på kasse: control module part number: 8d0 927 156 S component and/or version AG5 01V 1.8l5VT RDW 63 software coding 00000 Work shop code: WSC 00000 00268- solenoid valve 6 (n93) 28-10 short to plus - intermittent 00293- shareware version. to decode all DTCs 27-00 please register/activate 18179 shareware version. to decode all DTCs p1771-35-10 please register/activate - intermittent 00532- supply voltage b+ 38-00 output won`t switch or short to plus 00266 shareware version. to decode all DTCs 28-10 please register/activate - inter mittent Siter lfsnorge.net Lenke til kommentar Del på andre sider More sharing options...
Quattro73 Skrevet November 19, 2013 Rapporter Share Skrevet November 19, 2013 18179 (med flere) kommer opp fordi du har en piratkabel ;) 00268 - Solenoid Valve 6 (N93): Open or Short to Ground Possible Causes Wiring/Connectors from/to Solenoid Valve 6 (N93) Open or Short to Ground Solenoid Valve 6 (N93) faulty Possible Solutions Check/Repair Wiring/Connectors from/to Solenoid Valve 6 (N93) Check/Replace Solenoid Valve 6 (N93) See Measuring Value Blocks (MVB) Perform Output Test Special Notes On some transmissions, the OE wiring diagrams do not have Solenoid Valve 6 (N93), it can be refereed to as the Pressure Control Valve 3 (N217). Siter Bilforumet.no Administrator Lag en tråd om du lurer på noe, ikke send PM. Lenke til kommentar Del på andre sider More sharing options...
