Radio Kode.
Crazy Corsa
12 Can I use VAG-COM to retrieve my Radio Code to get it out of "SAFE" mode?
No, You'll need to get the radio code from your dealer (it should also be on a card that came with your car). Neither VAG-COM nor the factory tool can retrieve the radio's security code for you. (On some late model cars the factory may be required, but it does not retrieve the code from the car, it gets it from a server belonging to VW/Audi). In many cases (particularly MY 2000 and newer cars), the radio will be in SAFE mode after disconnecting the battery, but it will automatically exit that mode after a period of time, as long as it is still installed in the same vehicle.
fant dette da jeg googlet litt:) hør med din lokale forhandler av audi/vw:)
ok.. takk for info.. :)
96 Omega 3.0 v6 24v CD Prosjekt Tråd
X 94 Crazy Corsa
