vwsportz Skrevet Mai 4, 2006 Rapporter Share Skrevet Mai 4, 2006 disse verdiene var jeg å tok ned hos kollevold...vet ikke hvordan av dem jeg skal bruke på en 1,8 gti 8 ventilers..er ikke sikker på hvordan årsmodell jeg har..enklest måte å finne ut av dete på? 1985 VOLKSWAGEN Golf GTI 1.8L L4 F/I 33-2001 Product Specifications Product Style: Panel Air Filter Height: 1.625 in (41 mm) Outside Length: 13.25 in (337 mm) Outside Width: 5.188 in (132 mm) Filter Re-Oiling Amount: 1.28 oz (38 ml) Inner Wire: No Top Style: Open Weight: 1.1 lb (0.5 kg) Product Box Length: 13.5 in (343 mm) Product Box Width: 7.75 in (197 mm) Product Box Height: 1.75 in (44 mm) 1986 VOLKSWAGEN Golf GTI 1.8L L4 F/I – All 33-2001 Product Specifications Product Style: Panel Air Filter Height: 1.625 in (41 mm) Outside Length: 13.25 in (337 mm) Outside Width: 5.188 in (132 mm) Filter Re-Oiling Amount: 1.28 oz (38 ml) Inner Wire: No Top Style: Open Weight: 1.1 lb (0.5 kg) Product Box Length: 13.5 in (343 mm) Product Box Width: 7.75 in (197 mm) Product Box Height: 1.75 in (44 mm) 1987 VOLKSWAGEN Golf GTI 1.8L L4 F/I – All 33-2001 Product Specifications Product Style: Panel Air Filter Height: 1.625 in (41 mm) Outside Length: 13.25 in (337 mm) Outside Width: 5.188 in (132 mm) Filter Re-Oiling Amount: 1.28 oz (38 ml) Inner Wire: No Top Style: Open Weight: 1.1 lb (0.5 kg) Product Box Length: 13.5 in (343 mm) Product Box Width: 7.75 in (197 mm) Product Box Height: 1.75 in (44 mm) 1988 VOLKSWAGEN Golf GTI 1.8L L4 F/I – All 33-2029 Product Specifications Product Style: Panel Air Filter Height: 1.063 in (27 mm) Outside Length: 12.125 in (308 mm) Outside Width: 7.188 in (183 mm) Filter Re-Oiling Amount: 1.36 oz (40 ml) Weight: 1.1 lb (0.5 kg) Product Box Length: 13.5 in (343 mm) Product Box Width: 7.75 in (197 mm) Product Box Height: 1.75 in (44 mm) 1989 VOLKSWAGEN Golf GTI 1.8L L4 F/I – All 33-2001 Product Specifications Product Style: Panel Air Filter Height: 1.625 in (41 mm) Outside Length: 13.25 in (337 mm) Outside Width: 5.188 in (132 mm) Filter Re-Oiling Amount: 1.28 oz (38 ml) Inner Wire: No Top Style: Open Weight: 1.1 lb (0.5 kg) Product Box Length: 13.5 in (343 mm) Product Box Width: 7.75 in (197 mm) Product Box Height: 1.75 in (44 mm 1990 VOLKSWAGEN Golf GTI 1.8L L4 F/I – All 33-2029 Product Specifications Product Style: Panel Air Filter Height: 1.063 in (27 mm) Outside Length: 12.125 in (308 mm) Outside Width: 7.188 in (183 mm) Filter Re-Oiling Amount: 1.36 oz (40 ml) Weight: 1.1 lb (0.5 kg) Product Box Length: 13.5 in (343 mm) Product Box Width: 7.75 in (197 mm) Product Box Height: 1.75 in (44 mm) 1991 VOLKSWAGEN Golf GTI 1.8L L4 F/I - All 33-2029 Product Specifications Product Style: Panel Air Filter Height: 1.063 in (27 mm) Outside Length: 12.125 in (308 mm) Outside Width: 7.188 in (183 mm) Filter Re-Oiling Amount: 1.36 oz (40 ml) Weight: 1.1 lb (0.5 kg) Product Box Length: 13.5 in (343 mm) Product Box Width: 7.75 in (197 mm) Product Box Height: 1.75 in (44 mm) Siter vwsportz Lenke til kommentar Del på andre sider More sharing options...
Housey Skrevet Mai 4, 2006 Rapporter Share Skrevet Mai 4, 2006 hva med å fysisk MÅLE det gamle filteret? Siter Golf II 16vT Syncro Lenke til kommentar Del på andre sider More sharing options...
Joachim Skrevet Mai 4, 2006 Rapporter Share Skrevet Mai 4, 2006 Årsmodellen står vel i vognkortet? Er den orginal?, har den da pre 88 dører? Elimineringsmetoden ;) Siter Lenke til kommentar Del på andre sider More sharing options...
Polo Classic Skrevet Mai 4, 2006 Rapporter Share Skrevet Mai 4, 2006 33-2029 er til Digifant GTI med 107 hk og cat 33-2001 er til K-jet med 112 hk (med stålomspunnene slanger fra luftfilter til dyser) Siter No SPEAKERS NO BODYKITS NO BULLSHIT M3-speil, like moderne som bakrutesjalusi M3-speil, M3-sideskjørt og RS-fangere, også kalt nybegynnerfeil Lenke til kommentar Del på andre sider More sharing options...
vwsportz Skrevet Mai 4, 2006 Forfatter Rapporter Share Skrevet Mai 4, 2006 kan ikke måle filtrert fordi jeg ikke har det...har heller ikke boksen i nærheten..motoren står i en golf 1 ok da bestiller jeg 33-2001 har den med stålomspunnende slanger..takk for hjelpen Siter vwsportz Lenke til kommentar Del på andre sider More sharing options...
