KonThai Skrevet Mars 3, 2006 Rapporter Share Skrevet Mars 3, 2006 Selger en kjempe spiller som har sittet i bilen min siden jeg fikk den. Spilleren fungerer meget bra. Selgeren den fordi jeg skal over til P7500DVDII. Spilleren står montert i bilen og brukes daglig. Kan komme å vise den frem i Oslo området hvis det er intr. for det. Hbo 6000 Kr! Kun seriøse henvendelser! Siter Silvia S15 Lenke til kommentar Del på andre sider More sharing options...
Jonaldo Skrevet Mars 5, 2006 Rapporter Share Skrevet Mars 5, 2006 Gjør sånn jeg: Får ikke solgt noe uten bilder her på forumet vettu'...... Kongespiller dette da! Multi-Channel DVD AV Headunit You won't believe your eyes until you see it, hear it…and touch it. This multichannel DVD AV headunit, the star of Pioneer in-car entertainment, combines everything you want in the world of audio and visual: a sleek wide-screen 7-inch high-quality touch panel display, a high performance D4Q digital tuner, a MOSFET 5 x 50 W amp and DVD player. Operation of the AVH-P7500DVD is unbelievably fast and simple, thanks to its touch panel display complete with an exciting new GUI (Graphical User Interface). You control your audio, video and navigation settings with the touch of your finger. The ultra-slim built-in DVD player is compatible with all the latest digitally encoded discs, including high fidelity DVD-Audio for the audiophiles. Cinema fans will be stunned by the realistic cinematic soundtracks emerging from the 5.1 channels, courtesy of the Dolby Digital/DTS/Dolby Pro Logic II decoders. The built-in DSP (Digital Signal Processor) lets you customise your sound system to your taste with the Pioneer exclusive Multi-channel Auto EQ and Automatic Time Alignment. The IP-Bus connection means you can easily hook up extras like a TV tuner, DAB tuner or multi-CD player. Whether you want a great stand-alone AV system or a perfect addition to your Pioneer AVIC Cyber Navi unit, this compact AV headunit is the answer to your quest for the ideal in-car entertainment. Key features AVH-P7500DVD Fully Motorised Touch Panel Display Built-in DSP with Auto EQ and Automatic Time Alignment MP3, CD, DVD-Audio/Video Playback Dolby Digital / DTS / Dolby Pro Logic II Dual zone operation with front Video and rear AV output Back-up camera input D4Q Digital AM/FM tuner 6-channel Hi-Volt (5V) Pre-Outs General AVH-P7500DVD Amplifier MOSFET 50W x 5 Equaliser EEQ+ Equaliser med HPF, LPF & SFEQ CD Player Nei Built-in AM/FM RDS Tuner D4Q+ DVD Capabilities DVD-Video/Video CD/MP3 CD player 5.1-channel surround sound capability: - Built-in Linear PCM/MPEG-A/DTS/Dolby Digital/Dolby Pro Logic II decoder - 6-channel DAC & 6-channel DSP - Digital Sound Field Control (SFC) for multi-channel sources (Musical/Drama/Action/5D Theatre) DVD-Audio/DVD-Video/Video CD Playback with Direct Search Chapter/Track,Next/Previous Chapter/Track, Fast forward/reverse, Pause, Track/Chapter Repeat, Condition Memory (30 discs), Play back Control (Video CD only), Direct Search Title/Group, Time Direct Search, Scan, Digital Direct CD Capabilities CD Playback with Track Scan/Pause/Repeat, Random Play, CD Text, List Search MP3/CD-R/RW/CD-ROM, Random Play 96 KHz/24-bit DAC 24-bit D/A Converter Fast forward/reverse Track Search/Scan/Repeat Track/Manual search Last position memory Disc Title Memory Source Control MCD, SCD, TV DVD, DAB Tuner Control via frontpanelknappene eller fjernkontroll Voice Guidance Når den er koblet til Pioneer Navigasjonssystem Display type Wide Screen TFT active matrix LCD Color Display Touch Panel Operation Ja Display size 7,0 Inch Screen Coating High quality anti-Glare, Low-Reflection coating Installation possibilities In-Dash One-touch detachable display Nei Fully motorised display with auto dimmer with free adjustable viewing angle (50 - 110°) Front panel Removable with safety warning beep Selectable wide screen modes Just / Full / Cinema / Zoom / Normal Auto display brightness & backlight adjustment Nei Built-in speaker with volume control Nei Rear camera switching Ja Remote Control Included Dome light Nei D/A Convertor 24-bit DVD - R/RW and CD - R/RW Playback Ja Built-in MPEG 2/1 decoder Ja DVD video player Ja Region number 2 Connections AVH-P7500DVD AV Output 6-channel Hi-Volt (5V) RCA Pre-outs (FL+FR+RL+RR+Center+SW) AV inputs 1 RCA AV Bus Input Ja Input for rear camera Ja RGB input for Navigation System yes Optical Digital Output Nei IP Bus input/output Ja PAL/NTSC/SECAM compatible RGB input Nei Power Supply In Nei Rear monitor output Ja Siter Lenke til kommentar Del på andre sider More sharing options...
KonThai Skrevet Mars 5, 2006 Forfatter Rapporter Share Skrevet Mars 5, 2006 Takk :D Men spilleren på et blunk :D Gjør sånn jeg: Får ikke solgt noe uten bilder her på forumet vettu'...... Kongespiller dette da! Multi-Channel DVD AV Headunit You won't believe your eyes until you see it, hear it…and touch it. This multichannel DVD AV headunit, the star of Pioneer in-car entertainment, combines everything you want in the world of audio and visual: a sleek wide-screen 7-inch high-quality touch panel display, a high performance D4Q digital tuner, a MOSFET 5 x 50 W amp and DVD player. Operation of the AVH-P7500DVD is unbelievably fast and simple, thanks to its touch panel display complete with an exciting new GUI (Graphical User Interface). You control your audio, video and navigation settings with the touch of your finger. The ultra-slim built-in DVD player is compatible with all the latest digitally encoded discs, including high fidelity DVD-Audio for the audiophiles. Cinema fans will be stunned by the realistic cinematic soundtracks emerging from the 5.1 channels, courtesy of the Dolby Digital/DTS/Dolby Pro Logic II decoders. The built-in DSP (Digital Signal Processor) lets you customise your sound system to your taste with the Pioneer exclusive Multi-channel Auto EQ and Automatic Time Alignment. The IP-Bus connection means you can easily hook up extras like a TV tuner, DAB tuner or multi-CD player. Whether you want a great stand-alone AV system or a perfect addition to your Pioneer AVIC Cyber Navi unit, this compact AV headunit is the answer to your quest for the ideal in-car entertainment. Key features AVH-P7500DVD Fully Motorised Touch Panel Display Built-in DSP with Auto EQ and Automatic Time Alignment MP3, CD, DVD-Audio/Video Playback Dolby Digital / DTS / Dolby Pro Logic II Dual zone operation with front Video and rear AV output Back-up camera input D4Q Digital AM/FM tuner 6-channel Hi-Volt (5V) Pre-Outs General AVH-P7500DVD Amplifier MOSFET 50W x 5 Equaliser EEQ+ Equaliser med HPF, LPF & SFEQ CD Player Nei Built-in AM/FM RDS Tuner D4Q+ DVD Capabilities DVD-Video/Video CD/MP3 CD player 5.1-channel surround sound capability: - Built-in Linear PCM/MPEG-A/DTS/Dolby Digital/Dolby Pro Logic II decoder - 6-channel DAC & 6-channel DSP - Digital Sound Field Control (SFC) for multi-channel sources (Musical/Drama/Action/5D Theatre) DVD-Audio/DVD-Video/Video CD Playback with Direct Search Chapter/Track,Next/Previous Chapter/Track, Fast forward/reverse, Pause, Track/Chapter Repeat, Condition Memory (30 discs), Play back Control (Video CD only), Direct Search Title/Group, Time Direct Search, Scan, Digital Direct CD Capabilities CD Playback with Track Scan/Pause/Repeat, Random Play, CD Text, List Search MP3/CD-R/RW/CD-ROM, Random Play 96 KHz/24-bit DAC 24-bit D/A Converter Fast forward/reverse Track Search/Scan/Repeat Track/Manual search Last position memory Disc Title Memory Source Control MCD, SCD, TV DVD, DAB Tuner Control via frontpanelknappene eller fjernkontroll Voice Guidance Når den er koblet til Pioneer Navigasjonssystem Display type Wide Screen TFT active matrix LCD Color Display Touch Panel Operation Ja Display size 7,0 Inch Screen Coating High quality anti-Glare, Low-Reflection coating Installation possibilities In-Dash One-touch detachable display Nei Fully motorised display with auto dimmer with free adjustable viewing angle (50 - 110°) Front panel Removable with safety warning beep Selectable wide screen modes Just / Full / Cinema / Zoom / Normal Auto display brightness & backlight adjustment Nei Built-in speaker with volume control Nei Rear camera switching Ja Remote Control Included Dome light Nei D/A Convertor 24-bit DVD - R/RW and CD - R/RW Playback Ja Built-in MPEG 2/1 decoder Ja DVD video player Ja Region number 2 Connections AVH-P7500DVD AV Output 6-channel Hi-Volt (5V) RCA Pre-outs (FL+FR+RL+RR+Center+SW) AV inputs 1 RCA AV Bus Input Ja Input for rear camera Ja RGB input for Navigation System yes Optical Digital Output Nei IP Bus input/output Ja PAL/NTSC/SECAM compatible RGB input Nei Power Supply In Nei Rear monitor output Ja Siter Silvia S15 Lenke til kommentar Del på andre sider More sharing options...
Jonaldo Skrevet Mars 5, 2006 Rapporter Share Skrevet Mars 5, 2006 Men spilleren på et blunk :D Atte hva for no'.......? Siter Lenke til kommentar Del på andre sider More sharing options...
audi-oslo Skrevet Mars 23, 2006 Rapporter Share Skrevet Mars 23, 2006 heisaNN.. er int i spillern din.. send meh mail på pakistani425@hotmail.com med nummeret ditt så ringer jeg deg Siter Lenke til kommentar Del på andre sider More sharing options...
otemag Skrevet Mars 24, 2006 Rapporter Share Skrevet Mars 24, 2006 Er også interresert i spilleren din. Send meg mail på magnusoterhals@hotmail.com Siter Lenke til kommentar Del på andre sider More sharing options...
Clinton Skrevet Mars 24, 2006 Rapporter Share Skrevet Mars 24, 2006 Byr 5000 Siter Lenke til kommentar Del på andre sider More sharing options...
otemag Skrevet Mars 24, 2006 Rapporter Share Skrevet Mars 24, 2006 Byr 6200 Siter Lenke til kommentar Del på andre sider More sharing options...
