ftpfloppy Skrevet August 17, 2010 Rapporter Share Skrevet August 17, 2010 (endret) Heisann :) Har fått skaffa 2 stk Kicker Solo-Baric L7 12" oxo lurer jeg igrunn på hvor stor forsterker jeg må bestille :) Har alt det andre jeg trenger bortsett fra forsterker så kom med forslag :) Takk for forslag og tips :) Endret August 17, 2010 av ftpfloppy Siter Lenke til kommentar Del på andre sider More sharing options...
ftpfloppy Skrevet August 17, 2010 Forfatter Rapporter Share Skrevet August 17, 2010 Vil denne gjøre jobben ? * Max Series 2-Channel Car Amplifier * RMS Power Rating (14.4V): o 4 ohms: 200 watts x 2 chan. o 2 ohms: 300 watts x 2 chan. o Bridged, 4 ohms: 4000 watts x 1 chan. * RMS Power Rating (THD): o 4 ohms: 300 watts x 2 chan. o 2 ohms: 400 watts x 2 chan. * Max power output: 2000 watts x 2 chan. * Stiffly regulated PWM (Pulse Width Modulated) MOSFET power supply * LED power (green) and protect (red) indicators * Bass Boost/EQ details (0 or +18 dB bass boost) * Input impedance: 10K Ohms * 2/1 channel operation * Preamp RCA outputs * 3-Way System Protection circuitry (thermal, overload, and speaker short protection) * Variable input level: 200mV-6V * Heavy duty aluminum alloy heatsink for maximum heat dissipation * Nickle-plated RCA level inputs * Nickle-plated screw terminals * Variable high-pass filter (40-250 Hz, 24 dB/octave) * Variable low-pass filter (40-250 Hz, 24 dB/octave) * Phase Shift: 0-180° * Frequency response: 15-30,000 Hz * Dimensions: 17"L x 10-5/8"W x 1-3/4"H * 4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier. * Authorized Internet Dealer * 1-year Manufacturer's warranty Siter Lenke til kommentar Del på andre sider More sharing options...
todleif Skrevet August 18, 2010 Rapporter Share Skrevet August 18, 2010 Det er nok altfor liten forsterker du har valgt. Først må du finne informasjon om watt suben tåler og kva motstand spolen(e) har, slik at du finner ein forsterker som matcher effekten med den motstanden høgtalerene gir. Eg googla og fann ut at suben skal tåle 750w. sia du har 2 stk, er det greit med ein forsterker som gir ut ca 1500w med den motstanden høgtalerene har. Antagligt har suben 2 spoler på 4ohm. Med 2 stk høgtalere, kan du koble i 1ohm eller 4ohm. (gidder ikkje forklare dette no, sia eg skal legge meg snart, men kan forklare dette seinare) Til sub er det greiast med ein monoforsterker. So da er det å finne ein forsterker som gir ut rundt 1500w i 1 eller 4ohm Siter Bilforumet.noModerator: Bilpleie - Bilstereo -2003 Volvo S60 2.4D-1981 Porsche 911 Turbo Lenke til kommentar Del på andre sider More sharing options...
ftpfloppy Skrevet August 18, 2010 Forfatter Rapporter Share Skrevet August 18, 2010 Da har jeg fått skaffet denne :) http://www.sonicelectronix.com/item_11552_Kicker+08ZX1500.1+-ZX1500.1-.html hehe :) Siter Lenke til kommentar Del på andre sider More sharing options...
todleif Skrevet August 19, 2010 Rapporter Share Skrevet August 19, 2010 Da har jeg fått skaffet denne :)http://www.sonicelectronix.com/item_11552_Kicker+08ZX1500.1+-ZX1500.1-.html hehe :) Altfor liten forsterker det og. Den er på 750w Siter Bilforumet.noModerator: Bilpleie - Bilstereo -2003 Volvo S60 2.4D-1981 Porsche 911 Turbo Lenke til kommentar Del på andre sider More sharing options...
ftpfloppy Skrevet August 20, 2010 Forfatter Rapporter Share Skrevet August 20, 2010 Okei? Ble anbefalt denne på Sonicelectronix men? Max power output approximately 4500 watts x 1 chan. Kan du finne en på sonicelectronix.com som er grei da? så er du en pus :P Siter Lenke til kommentar Del på andre sider More sharing options...
todleif Skrevet August 20, 2010 Rapporter Share Skrevet August 20, 2010 (endret) Maks watt er total bortkasta opplysning. det er rms watt som du skal sjå etter. Sia du skal ha 2 subber på 750w rms, er det greit med ein forsterker som skal drive dette. (750 x2 = 1500) Ellers får like godt trøkk med berre 1 sub. Ulempen med at du skal ha 2 subber som tåler litt effekt, er at du "må" ha ein kraftig forsterker. Det er sikkert mange meininger om dette, men som sagt synes eg at det er totalt bortkasta med 2 subber og for liten forsterker. Da er det like greit med 1 sub som kan spille like høgt. (eg kan væra litt krass når eg skriver, men det trenger du ikkje å tenke på. Eg er ikkje typen som bruker for mange smilefjes) Og so får eg sjå om eg finner ein forsterker til deg: http://www.sonicelectronix.com/item_12019_Alpine+MRP-M2000.html http://www.sonicelectronix.com/item_23964_Soundstream+DTR1.2200D.html http://www.sonicelectronix.com/item_23986_Soundstream+RUB1.2500D.html Endret August 20, 2010 av todleif skriveleif Siter Bilforumet.noModerator: Bilpleie - Bilstereo -2003 Volvo S60 2.4D-1981 Porsche 911 Turbo Lenke til kommentar Del på andre sider More sharing options...
ftpfloppy Skrevet August 20, 2010 Forfatter Rapporter Share Skrevet August 20, 2010 Takk for bra svar :) Tror jeg følger rådet ditt, hørte me en kompis i stad, og han sa akkuratt det samme som deg ! Så kommer nok til å gå for den Alpine forsterkeren da :) Siter Lenke til kommentar Del på andre sider More sharing options...
