Klarer denne å dra disse?
Pålarn
Hei.
Vanskelig å finne tittel på topicen så den ble litt rar dårlig..
Men det jeg lurte på er om 1 stk. Pioneer PRS-D3000SPL klarer å dra 2 stk. Pioneer TS-W3004SPL.
Legger ved info om begge to jeg så får dere se! Har ikke så mye greier på det :)
PRS-D3000SPL:
Competition Class SPL Class-D Amplifier
Take your in-car sound to the edge with this Class-D SPL amp. Designed to match our first-class SPL subwoofers, it puts out a razor-hot 2000 W of max. output power.
This amp is outfitted with an Independent Rail Regulating Power (IRRP) supply and a new Low Current Density (LCD) design. Highly efficient Class-D technology is part of the construction too. Less current for less heat. That means no distortion, so the sound always stays pure, crisp and clear.
Key features PRS-D3000SPL
Max. output power: 1000 W x 1 (4 Ohm) / 2000 W x 1 (2 Ohm)
Continuous output power (14.4 V): 1 x 500 W (20 - 240 kHz / 4 Ohm), 1 x 1000 W (20 - 240 kHz / 2 Ohm), 1 x 3000 W (Bridged 4 Ohm)
Load impedance capability: 4 Ohm (2 - 8 Ohm allowable)
Specifications PRS-D3000SPL
Maximum Output Power 1000 W x 1 (4 Ohm) / 2000 W x 1 (2 Ohm)
DIN power output (W)
(DIN45324, +B = 14.4V) 800 W x 1 (4 Ohm) / 1400 W x 1 (2 Ohm)
# Continuous power output (RMS) 14.4V (20Hz-20kHz/2ohms): 1 x 1.400W
# 14.4V (20Hz-20kHz/4ohms): 1 x 800W
Load impedance capability 2 -8
Frequency response 10 Hz - 240 Hz Hz
Distortion <0.05 %
S/N ratio >90 dB
LPF 40 - 240 Hz
Speaker Terminals Block-type
High performance balanced isolator circuit Ja
Max. current consumption (A/4ohms) 42 A
Chassis size (W x H x D) 300 x 64 x 279 mm
Unit weight 5.9 kg
General PRS-D3000SPL
Anbefalt utsalgspris 6.998,-
TS-W3004SPL:
TS-W3004SPL konkurransesubwoofer er på hele 3000 W maksimal utgangseffekt og matchet med de nye Pioneer SPL forsterkerne, vil den bli en vinner i konkurranser, samtidig som den vil være perfekt i vanlige lyttemiljøer. Essensielle finesser er hentet fra toppmodellen TS-W5000SPL, i tillegg til førsteklasses, forbedret lydgjengivelse og effekthåndtering. Den nye doble membranstrukturen tåler ekstreme SPL lydtrykk, mens forsterket, lavtdempende, utslagskontrollert luftopphengssystem forbedrer holdbarheten. Større fleksibilitet på subwoofer-kassene sikrer formidabel lyd, uansett om den er montert i en større eller mindre kasse.
Key features TS-W3004SPL
Interlaced Glass/Carbon Fibre Reinforced IMPP double cone
Wide-roll, 3-layer Fibre woven radial surround
Double cone reinforcement nodes
Powerful double-stacked magnets
High power handling ceramic-coated voice coils
Bottom hold design aluminium die-cast chassis
Aluminium die-cast heat sink
Spring compression binding terminals
Nominal input power: 1000 W
Features TS-W3004SPL
Frequency response 18 - 700 Hz
Sensitivity (1W/1m) 89 dB
Recommended sealed enclosure (Litres) 24.1 - 49.5
Lowest resonance frequency (FS) 26.2
Maximum input power 3.000 Watt
Nominal input power 1.000 Watt
Woofer size (cm) 30 cm
Dual 4Ω voice coils: 2 or 8Ω Yes
General TS-W3004SPL
Anbefalt utsalgspris 2.198,-
Klarer 1 stk Pioneer PRS-D3000SPL å dra 2 stk Pioneer TS-W3004SPL bra? Eller skal jeg smelle til med 2 stk PRS-D3000SPL?
MVH Påål :D
Kjøretøy: 1, 2 (SELGES), 3, 4, 5, 6
Har du råd så er det vel ikke noe å tenke på? ;D
Neimen 1 klarer jo å dra de, selv om det er tunge elementer, men du vil såklart få mye mer ut av de om du har 1 på hver!
Her er vel nesten lommeboka det eneste som bestemmer vil jeg påstå ;)
