Er forsterkeren bra nokk?
raz
Forasterker
MarQuant MCA-4200
¤ 200w x 4 channel maximum power output
¤ 95w/channel RMS continuous output @ 0,5% THD (20Hz, both channels driven into 4 ohm load)
¤ Mono bridgeable to 600w outputs
¤ Multi-mode connection capability for simultaneous subwoofer & satellite speaker operation
¤ Adjustable subwoofer crossover frequenzy (40Hz-250Hz)
¤ High current Discrete output devices
¤ Adjustable RCA level inputs
¤ Input ground isolation noise rejection circuit
¤ Mosfet power supply technology
¤ 2 ohm stable output
kan denne forsterkeren drive:
12*1000W 500rms å
Høytalere!
6.5'' 2 veis komponetnsett,med innebygget leds.
Poly membran
Gummi oppheng
180 Watt RMS/360 Watt Max
Frekvens respons: 60Hz-6KHz (Mid-Bass)
4 Ohm
1/2" diskant
Frekvens respons: 3k-22KHz
12dB Octave delefilter
Kan denne forsterkeren drive dette??
Kjør hart kjør me stil gjør GTI bil...:P
