GalantV6 Skrevet April 5, 2005 Rapporter Share Skrevet April 5, 2005 Er det noen som kan si noe om denne forsterkeren og om denne vill spille bra. Vurderer å kjøpe en for å drive 2 stk Audiobahn AW121T 12" SPL XL21200 2Channel 1200Watts Full Mosfet Power Supply PWM Circuitry Chrome Plated Side Panels Full Selectable Crossover Hi/Full/Low Three Way Protection Circuit 2-Ohm Stable Stereo Tri-Mode Capable Variable Low Pass 40Hz-120Hz Variable Hi Pass 150Hz-1.5Khz 18dB Bass Boost @ 40Hz. Frequency Response: 10Hz to 30Khz S/N Ratio: 97 db THD: 0.02% System Distress Indicator High/Low Level Inputs With Floating Ground 4 Gauge Power/Ground Connection Gold Plated RCA Connectors Line Output 2 Channel 4 Ohm Rms:250 x 2 2 Ohm Rms:300 x 2 Mono Rms: 460 Bridget Max: 1200 Audiobahn AW121T 12" Car Subwoofer 12" Subwoofer 550 Watts RMS Power Handling 80 oz. Magnet Weight 92.8 dB Sensitivity 26 - 1,000Hz Frequency Response 4 ohms Impedance Dual Voice Coil PHAT 2” Foam Surround Thick, Chrome Flame Style Basket KM3’ Coated for Virtually No Cone Distortion Non-Pressed, Non-Transfer Paper Cone Multi-connect Lug Lock Terminal Siter Lenke til kommentar Del på andre sider More sharing options...
