clone baby Skrevet Mars 9, 2005 Rapporter Share Skrevet Mars 9, 2005 Hei, vurderer og kjøpe en fuel Cut Defencer for og flytte/fjerne fuel cut pungte litt høyere opp i registeret, men lurte på hvilken måte jeg skulle gjøre det på. Bilen er en Colt Turbo 88mod.. Enten Pneumatic Fuel Cut Defender Accurately increase the factory fuel cut out when increasing boost pressure, no cutting or splicing wires. * Suited to most turbo cars that use a MAP sensor to determine the fuel cut level * Allows you to increase the factory fuel cut, without effecting off boost conditions * Can be locked to prevent tampering Eller Electronic Fuel Cut Defender Accurately eliminate the factory fuel cut out when increasing boost pressure. * Features simple adjustment with L.E.D. indicator for easy set-up * This FCD has a compact water-resistant housing * Suitable for under bonnet installation Siter CorsaA 1.8 16vT CorsaA 1.3 http://www.bilforumet.net/faq.php Lenke til kommentar Del på andre sider More sharing options...
Einar Skrevet Mars 20, 2005 Rapporter Share Skrevet Mars 20, 2005 Hei, vurderer og kjøpe en fuel Cut Defencer for og flytte/fjerne fuel cut pungte litt høyere opp i registeret, men lurte på hvilken måte jeg skulle gjøre det på. Bilen er en Colt Turbo 88mod.. Enten Pneumatic Fuel Cut Defender Accurately increase the factory fuel cut out when increasing boost pressure, no cutting or splicing wires. * Suited to most turbo cars that use a MAP sensor to determine the fuel cut level * Allows you to increase the factory fuel cut, without effecting off boost conditions * Can be locked to prevent tampering Eller Electronic Fuel Cut Defender Accurately eliminate the factory fuel cut out when increasing boost pressure. * Features simple adjustment with L.E.D. indicator for easy set-up * This FCD has a compact water-resistant housing * Suitable for under bonnet installation en bil som ikke har turbo orginalt har velm heller ikke fuel-cut ved høyt ladetrykk. Siter Bilforumet.noÆres Super Moderator `84 Ford Granada 2.3 L Turnier`92 Ford Scorpio 2.9 GL Lenke til kommentar Del på andre sider More sharing options...
Peet Skrevet Mars 20, 2005 Rapporter Share Skrevet Mars 20, 2005 kasnskje ikke d.. men denne bilen har orginalt turbo då.. doh Siter Volvo 740/940 Turbo Ford Sierra 1,8TD Ford Escort Mk2 Lenke til kommentar Del på andre sider More sharing options...
clone baby Skrevet Mars 21, 2005 Forfatter Rapporter Share Skrevet Mars 21, 2005 kasnskje ikke d.. men denne bilen har orginalt turbo då.. doh Stemmer det, er org turbo colt, men virker som ingen kan ambefale meg hvilken jeg bør kjøpe for og fjerne fuelcut problemet mitt :( Siter CorsaA 1.8 16vT CorsaA 1.3 http://www.bilforumet.net/faq.php Lenke til kommentar Del på andre sider More sharing options...
realace Skrevet Mars 21, 2005 Rapporter Share Skrevet Mars 21, 2005 Stemmer det, er org turbo colt, men virker som ingen kan ambefale meg hvilken jeg bør kjøpe for og fjerne fuelcut problemet mitt :( Ta en titt på sidene til HKS Mvh Siter 02 Mitsubishi Lancer Evolution 7 RSII 10 Mitsubishi ASX instyle+ http://www.lancerregister.com Lenke til kommentar Del på andre sider More sharing options...
