erlnor12 Skrevet August 9, 2013 Rapporter Share Skrevet August 9, 2013 (endret) Adaptronic 440 Datasprut selges. Ledningsnett, vanntemp føler, lufttemp føler, datakabel og noen andre ledninger følger med! Ubrukt. HBO.5000,- Kan sendes! -92443822 HELST SEND SMS / RING VED INTRESSE! Features "3D" Fuel and Ignition maps (as on any sophisticated aftermarket ECU) Configurable ignition and injection outputs to suit different applications Inputs for water temperature, air temperature, auxiliary temperature (eg turbo), external Manifold Air Pressure sensor, Throttle Position Sensor, knock sensor, EGO (exhaust gas oxygen) Internal MAP sensor suitable for up to 40 psi of boost Outputs for four injector groups - allows full sequential injection up to 4-cylinders, or semi-sequential injection up to 8- cylinders Outputs for four igniter groups - allows full sequential spark up to four cylinders and wasted spark systems up to 8-cylinders, or any conventional distributor systems Eight configurable auxiliary outputs - four of which are configurable as high current outputs, three of which are PWM capable Eight configurable digital inputs Numerous diagnostic LEDs, including LEDs to indicate trigger input detection and injector/ignition outputs 3.5mm headphone jack for listening to knock PC interface via USB cable Field upgradeable firmware Datalogging via 'WARI' PC software Free support by forum and email 12 month 'return to base' warranty Adaptive fuel control - with configurable tolerances and loop gains, and conditions under which adaptive behaviour takes place Narrow-band (factory EGO sensor) closed loop fuel control Flex Fuel control (requires fuel composition sensor to be fitted) High current programmable outputs - allows direct drive of solenoid valves for boost control, air bypass etc Special function programmable outputs - allows control of anti-pollution purge valves, air conditioners etc Open-loop and closed-loop idle bypass control - allows configuration of increased idle bypass amount based on low battery, electrical load, air conditioner, as well as correction based on RPM, optional ignition timing control for idle speed regulation Programmable for many different crank/cam angle sensor waveforms Open-loop and closed-loop boost control Dual closed-loop variable valve timing (VVT) channels Traction control and launch control Many other features Endret August 9, 2013 av erlnor12 Siter Passat 3BG 1.8T Prosjekt! -Your girl is like my car. I SLAMMED BOTH! Lenke til kommentar Del på andre sider More sharing options...
erlnor12 Skrevet August 12, 2013 Forfatter Rapporter Share Skrevet August 12, 2013 BLIR HENTET ONSDAG 14.08.13 ! Har bud på 5000,- Førstemann med 6000,- innen Tirsdags kveld får det ! Siter Passat 3BG 1.8T Prosjekt! -Your girl is like my car. I SLAMMED BOTH! Lenke til kommentar Del på andre sider More sharing options...
