D7S-SPL Dynamics 1-Ch D amplifier. 7000watts 1 ohm
Jokke_
Må selge denne pga. pengeproblemer!
Selger den derfor for 15000kr siden ny prisen på den er 20598,-
forsterkeren er ubrukt, ligger helt ny i innpakning.
Ring eller send sms for info. pris kan diskuteres ved hurtig avgjørelse! tlf 97642444
Litt info om forsterkeren:
Dette er en videreutvikling av D7. Mer effektiv på lavere spenninger.
SPL Dynamics D-series amplifiers have been developed especially for dB Drag Racing
competition use. The wide operation voltage range allows them to be used from
street class with single 12V battery to extreme class with heavy duty high
voltage battery banks. All models operate in class D with high
effiency and can be linked to achieve double output power.
Specifications D-7
Numeber of channels 1
RMS Power 1 Ohm ( 12.0V ) 4700W
RMS Power 1 Ohm ( 14.4V ) 6500W
RMS Power 1 Ohm ( 16.0V ) 7300W
RMS Power 1 Ohm ( 18.0V ) 8600W
2pcs linked
RMS Power 2 Ohm ( 14.4V ) 13000W
RMS Power 2 Ohm ( 16.0V ) 14600W
RMS Power 2 Ohm ( 18.0V ) 17200W
THD < 1%
Input sensitivity 0.2 - 6 V
Lowpass filter 35 - 250 Hz
Subsonic filter 10 - 50 Hz
Phase control 0 - 180 degrees
Remote level control Yes
Two amp linkable function
(Output Master/Input Slave) Yes
2 x 0 Gauge power supply connectors Yes
Line output Yes
Dimensions ( W x H x L ) 284 x 67 x 770 mm
