Selges: Stort koplett bilstereo anlegg
knekt
Alpine V12 MRV-F540
» 80 watts RMS x 4 at 4 ohms
» 100 watts RMS x 4 at 2 ohms
» 200 watts RMS x 2 in bridged mode
» 2-, 3-, or 4-channel output
» Tri-way capable (Tri-Way Crossover required)
» requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
» Bass Engine® features front and rear high-pass (variable 15-8,000 Hz)/low-pass (variable 30-8,000 Hz)
crossovers, 12 dB/octave
» MOSFET power supply
» STAR Topology (minimizes internal noise and prevents ground interference)
» preamp outputs
» oversized power and ground connections
» gold-plated screw terminals
» top mounted controls with cover
» detachable front cover
» blue power LED
» 16-1/2"W x 2-1/2"H x 9-7/8"D
Alpine V12 MRD-M1000 Specifications
Features:
General-Amplifiers
* 8.5 Volt Input Capability
* Alpine V12 PWM Power Supply
* Bass Engine® DSP(Parametric EQ, Crossover, Time Correction, Phase Control, Subsonic Filter, Bass Compensator)
* Blue Power Indicator
* Control Panel Cover
* Digital Control Center with LCD Display (Voltage, Current, and Temp Indicator)
* Gold Plated Power Screw Terminals
* Gold Plated Speaker Screw Terminals
* Integrated Wire and Mounting Screw Covers
* RCA PreOutput (L, R)
* Remote Bass Knob or Remote Amplifier Control Center (RACC) Ready
* STAR Topology
* Safe Mode
* Top Mounted Controls
* V12 AccuClass-D™ Design
* Variable Turn-On Delay
Specs:
Bass Engine®
* Bass Compensation : 3-Level
* Crossover Type : 24dB/Octave Slope - Digital
* Low Pass Crossover Frequency (Selectable) : 30Hz - 200Hz (1/12 oct. Steps)
* Number of Time Correction Channels : 1
* Parametric EQ "Width" (Selectable) : 0.5,1,2,3,4,5 ("Q")
* Parametric EQ Frequency (Selectable) : 30Hz - 160Hz (1/12 Oct. Steps)
* Parametric EQ Level (Selectable) : ±12dB (1dB Steps)
* Subsonic Filter Range : 15Hz - 50Hz (5Hz Steps) or OFF, 24dB/octave Slope
* Subwoofer Level Adjustment Range (With RUX-4180 or RUX-4280 Connected) : -15dB to 0dB (1dB steps)
* Subwoofer Phase Control : Normal (0°) or Reverse (180°)
* Time Correction Adjustment Range : 0 - 10 mSec. (0.1mSec. Steps)
General-Amplifiers
* Analog-Digital Conversion : 24Bit/96kHz
* Foot Print (WxHxD)in : 9-3/4" x 2-1/2" x 21-21/32"
* Foot Print (WxHxD)mm : 247mm x 65.84mm x 550mm
* Frequency Reponse : 10Hz-500Hz (+0, -1dB)
* Gain Factor : 0/+6 /+12dB
* Heat Sink w/Cover (WxHxD)in : 11-7.16" x 2-1/2" x 21-1/32"
* Heat Sink w/Cover (WxHxD)mm : 290.5mm x 65.84mm x 550mm
* Input Impedance : 10k ohm
* Input Level : 0dB to -24dB, 1dB Steps
* Input Sensitivity (for rated power) : 0.5V to 8.5V
* Memory : None Volatile, EEPROM
* Pre-amp Output : up to 8.5V RMS, Buffered
* Safe Mode : On/Off (Output Disable)
* Signal to Noise (S/N) : 100dBA (referenced to rated power)
* Speaker Impedance : 4 or 2 ohms (Mono)
* Variable Turn-on Delay : 0-2s, 0.25s Steps
* Weight (Kgs) : 8kgs
* Weight (lbs) : 17.7 lbs
MAX Power (at 14.4V,EIAJ)
* Bridged 2 ohms : 1600W x 1 (20-200Hz/1% THD)
RMS Power (at 12V,20Hz-200Hz)
* Per channel into 2 ohms : 700W x 1 (1% THD)
* Per channel into 4 ohms : 350W x 1 (1% THD)
RMS Power (at 14.4V,20Hz-200Hz)
* Per channel into 2 ohms : 1000W x 1 (1% THD)
* Per channel into 4 ohms : 500W x 1 (1% THD)
Amega Qcomp 60 - 100w 4ohm
Alpine SPX-177A
Key Features: 6-3/4" hemp-fiber woofer cast aluminum woofer frame nitrobutylene rubber
(NBR) surround 1" hand-coated textile dome tweeter swivels up to 30 (surface- and flush- mounting)
2-way crossover with extensive adjustment circuitry biamp or single input operation
frequency response 35-35,000 Hz recommended power range 8-60 watts RMS
peak power handling 240 watts sensitivity 90 dB top-mount depth 2-3/4"
ROCKFORD FOSGATE
HE2 RFP4212 Dual 4-ohm Voice Coil 12" Sub
Peak Power Handling 800Watts
RMS Power Range 100-400Watts
Impedance ( Ohms ) 4
Free-Air No
Dual Voice Coil Yes
Sensitivity 86dB
Frequency Response 28-0.2KHz
Cone Material Polypropylene
Surround Material BART Foam
Dimensions
Sealed Box Volume (cu ft 0.9-2.79
Ported Box Volume (cu ft) 1.75-4
Top Mount Depth 6-3/16"
Cutout Diameter or Length 11-1/8"
Size 12"
anlegget har vært i bruk i ca 15t....selges pga ikke no bil og ha det i lenger
selges høystbydende.....kom med bud
