hummm Skrevet Mars 15, 2008 Rapporter Share Skrevet Mars 15, 2008 Gratulerer ja :) 180hk finner en i Leon 20vt, noen A3`er, A4 TSQ (Sport), og sikkert noen A6er.. Hvertfall på A4 markeres det med en rød T ja.. All the following turbos have the same installation dimensions andthermodynamical performance. The differences are only in the actuator that opens the turbine bypass valve: K03-011 (5303 988 0011) 150 hp, 65 N actuator K03-026 180 hp, 85 N actuator K03-035 180 hp, 85 N actuator K03-044 150 hp, 65 N actuator K03-045 156 hp (Ibiza Cupra), 85 N actuator with 2 ports K03-049 150 hp (Sharan/Alhambra), 65 N actuator The 180 hp versions have an actuator with a higher opening force due to the higher exhaust gas pressure (which is a consequence of the higher boost pressure). Otherwise the valve would be pushed open by the exhaust gas pressure. The following turbos are a further development (since 2000) and have an improved and slightly larger compressor while using the same turbine (still with the same installation dimensions): K03-052 180 hp, 85 N actuator K03-053 150 hp, 85 N actuator K03-058 150 hp/180 hp, 85 N actuator Consequentially, putting a 180 hp turbo on a 150 hp engine will not bring about any change in performance, but putting on a K03-052/053/058 instead of the older versions will bring a slight improvement in engine efficiency. Additionally, with re-mapping the ECU you can achieve about 215 hp without danger of overspeeding the turbo. With the older turbos, 195 hp is the limit. Siter BMW 535D Hartge X:Audi A6 1,8TQ, Audi RS2 MTM Lenke til kommentar Del på andre sider More sharing options...
