Motornummer
Vet du hva?
Ved hjelp av http://www.google.com så fant jeg ut dette:
Engine Code Stamping Numbers
All engines are stamped with an engine ID code, consisting of assembly plant code, production date and suffix code. V8 codes are stamped on a pad just forward of the right side (passenger) cylinder head. 6 cylinder engines are stamped on the passenger side of the block behind the distributor.
Rart hva en finner på internett gitt! :D
-Out of order-
Vet du hva?
Ja ikke sannt, takk for hjelpa:)
