Side assist virker ikke på A5
AudiET
Så denne på nettet.
I also hooked up the VAG COM to my car and checked for Fault codes for the Side Assist. I'm getting fault code "16365-Control Module -Electrical Error, CPU 2; 014- Defective"... According to my research, this sensor is located in the bumper and has to be replaced. Anyone had this issue before and knows where I can find a fairly cheap sensor? Will replacing that one sensor solve the problem or will I have to replace other sensors as well? Again thanks for the information.
